Series III Timing Chains [Cam Chains]
jfjharry
#1 Series III Timing Chains [Cam Chains]
Post by jfjharry » Fri Mar 08, 2013 12:01 pm
If anyone with a Series III has had a timing chain that needed replacing I would be interested to know what your first indications were that the timing chain needed replacing.
I have a slight rattle noise from the front right hand side of the motor, it does get louder after a hard run on a hot day however when you stop the engine and rest it for about 5 minutes when you start up again the noise has gone yet on another day a slight rattle was there after the motor had been off for a couple of hours.
The motor is running perfect, no overheating etc. Is there any way of checking that the Timing Chain is too loose?
Harry
MarekH
Post by MarekH » Fri Mar 08, 2013 1:05 pm
Dear Harry,
Download a copy of Kirby Palm's "Experience in a Book" to have a read up about timing chains, amongst other things.
kind egards
