#1 I have lost all spark.
Posted: Sat Apr 06, 2013 1:13 pm
Hello again.
I'm not sure if this should be in the "technical" forum or series 3, apologies if I have put it in the wrong place.
After a few winter improvements to my engine, engine bay and a few other little bits I am now at the point where I am restarting the car again.
After a couple of turns she fired up nicely as hoped but as I built the revs (to about 2000 RPM) the engine cut out suddenly, no misfiring, no noises, she just stopped.
From what I can tell, the previous owner had the re-opus unit fitted. The car also appears to have a non original control box, it is marked up as a CAV 440, I completed 600 miles last year with this system and it performed very well, however I did have intermittent charging problems.
The fact that the engine ran fine for about 30 sec?s before stopping suggests a failure of a component rather than a loose connection where I would expect a gradual failure or intermittent sparking.
I have checked the entire system for anything obvious, all connections look OK. I have also worked through the repair operation manual checks as this is not an area that I am completely confident about. These are the readings I took.
I have battery voltage (13.1) at the SW terminal of the ballast resistor.
I have 3.7 V at the coil + terminal. (manual states 4 to 6V)
I have 1.2 ohms over the coil terminals. (manual states 0.8 ? 1.0)
I have 1.19V on the voltage drop test. (manual says replace amplifier if under 2V)
Ballast resistor (47229A) resistances are as follows:
1) LH mid terminal (SW) to RH top terminal (blue & white wire)-8.2 ohms
2) LH lwr terminal (Start) to RH mid terminal (black & red wire)-1.0 ohms
3) Across lwr terminals (start to white & green)-1.3 ohms.
Resiatances 2 & 3 seem a bit high compared to manual figures.
When I conducted the ?switching action test? I recorded a voltage of 1.2V, the manual states that this should be at battery voltage.
I have a good earth.
So if I follow the manual to the letter it would suggest I need to replace my Amplifier unit AND the Ballast resistor, I however am not convinced. The fact the car was firing perfectly and stopped instantly makes me think it should be a failure that is obvious to see and most of the undesirable readings above are only a bit out (With the exception of the switching action test).
I am hesitant to start throwing new parts at it until I am convinced that I know what is actually at fault. If anyone has any suggestions at all that might help then I am all ears! I am also keen to find out what caused the failure. If I do end up purchasing new parts I don?t want the same problem to happen due to not fixing the initial cause.
I have spent quite a few hours drinking tea and scratching my head with this and I?m all out of ideas!
Thanks in advance for any help, suggestions, advice or teabags.
Marcus.
Marcus.
