Looking in the tyrewell in the boot of my newly acquired S2+2, I found a round hole in the bottom right of the boot - it looks like a large drain hole (as it is at the lowest part of the boot) that should have a grommet in it.
I can't find this mentioned in the parts manual or anywhere else. Is this normal?
I presume that it is better with a grommet in it than not, particularly as it would let spray from the rear wheel in if I ever get caught out in the rain!
Missing Grommet?
#2 Grommet
What I did was fit a nice tight NEW grommet and then cut the middle out.
That allows the little bit of water out and a bit of fresh air in.
Water should not ingress through that particular grommet.
PS my boot is bone dry
DC
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
Thanks DC
So... The hole should be there, I can put a grommet in if I want, but leave/make a hole to stop the boot getting wet.
Did I get that right?
