#1 S3 V12 Frount mount Alternator upgrade.
Posted: Wed Dec 04, 2013 5:57 am
by sprog
Hi Guys,
I want to replace the alternator with a modern type. preferably one I can just go and order from repco.
I have seen a few kits for mounting it next to the engine, but I have an A/C pump there.
Does anyone know of a kit available? or have you done one DIY? What alternator did you use?
Thought I would ask around before I spent several hours going through the bosch catalogue to find something that would work.
#2 Altenator
Posted: Fri Dec 06, 2013 4:09 pm
by D COUPE
I also considered a modern alternator and its mounting position.
After talking to a few knowledgeable folk I retained the original Butec. Its big enough power wise. it is certainly well made. I think mine was the original one from new so. if you fit a new modern regulator box
I can not see a reason to change to a modern one............
DC
Posted: Sat Dec 14, 2013 5:26 am
by sprog
Replaced the alt with one from a 75-80 series Land cruiser. (110A) Gotta love Toyota stuff. (a 3UZ or 1GZ in an e-type would be awesome.)
Works perfectly, after some rewiring and bracket spacers etc.
Can post pics, if anyone is interested.
#4 Re: S3 V12 Frount mount Alternator upgrade.
Posted: Tue Nov 15, 2016 8:12 pm
by jagwit
I'm keen to upgrade the 50A Butec alternator on my car to at least a 90A unit. When the headlights, fans and aircon all are on simultaneously, the alternator just does not cope.
I would appreciate it someone could provide the make and model no of an alternator that would easily replace the Butec without too much mechanical mods.
#5 Re: S3 V12 Frount mount Alternator upgrade.
Posted: Tue Nov 15, 2016 10:56 pm
by MarekH
Dear Philip,
I fitted one from an XJS in the smog pump position. I did make a custom bracket for it out of 6mm thick angle iron, but you may find it'll fit some other way given your belt configuration will be different.
I expect someone local might be able to rewire yours for a higher output or perhaps think about looking into replacing as many bulbs as you can with LEDs.
#6 Re: S3 V12 Frount mount Alternator upgrade.
Posted: Wed Nov 16, 2016 12:23 am
by V12 Epyte
Fosseway have made one which replaces the Butec Alternator and Butec Regulator
http://www.fossewayperformance.co.uk/e- ... nator-kit/
#7 Re: S3 V12 Frount mount Alternator upgrade.
Posted: Wed Nov 16, 2016 8:56 am
by Whitact
I recently fitted one of these:
http://www.scparts.co.uk/sc_en/british- ... 01987.html.
Went straight in on the original brackets with minimal wiring mods.
#8 Re: S3 V12 Frount mount Alternator upgrade.
Posted: Wed Nov 16, 2016 6:18 pm
by jagwit
Importing one of these off-the-shelf kits is not an option for me as by the time I have it in my hands, the price has doubled.
It turns out I have 7 alternators lying around in my cupboards. I will MAKE one of these work and will post on my project once I have something worth sharing.
