#1 Bleeding Brakes on S3
Posted: Sat Dec 28, 2013 9:39 am
I'm just finally completing the conversion of my S3 Coupe from LHD to RHD and all's gone well. (See related previous thread).
Fired it up today and topped up coolant and power steering fluid then attempted to bleed the brakes. Managed to pump fluid through the front lines but couldn't get fluid through he back ones. The car has a Pressure Differential Warning Actuator (PDWA) fitted and according to the manual, I therefore need to bleed the brakes with the engine running. Tried that - no luck. Prior to the conversion, brakes worked well. Any suggestions? :(
