Mountain King
Post
by Mountain King » Sun Apr 06, 2014 1:49 pm
Silly me binned the old LP hose from the reservoir to the clutch/brake cylinders and the vacuum hoses before finding a replacement
. I have found this
https://www.merlinmotorsport.co.uk/s/br ... servo-hose
but to be clear, what is the actual inside diameter supposed to be? and any good supplyists outside of SNG, MR etc.
cheers
MK
1973 Series 3 OTC
- Administrator
Post
by Heuer » Sun Apr 06, 2014 3:01 pm
Mountain King
Post
by Mountain King » Sun Apr 06, 2014 3:26 pm
Thanks David,
good to know that i had decided on the correct hoses from Merlin, though more out of good luck rather than science!
cheers
MK
1973 Series 3 OTC
- Administrator
Post
by Heuer » Sun Apr 06, 2014 3:31 pm
Not the same hose! You need the one with Cohline 2337 writ large on it. You can also buy the correct hose from Hutsons.
Mountain King
Post
by Mountain King » Sun Apr 06, 2014 3:40 pm
thanks David,
I'm getting both the brake/clutch hose which is the Cohline 2337 and the vacuum hose (which was the link I posted)
cheers
1973 Series 3 OTC
