#1 Ist post, Alternator and other issues
Posted: Fri Jun 27, 2014 10:18 pm
Hi Folks, I have been working on a Series 3 V12 for a customer( I normally work on pre 1990 Mercedes) who has owned this rather nice car for some years but has been unable to start it. A previous mechanic has fitted BPR5 NGK plugs to make it easier to start ( didn't work) .I managed to get it to fire and sort of run after I overhauled the 6 weber IDF's ,but other things have cropped up such as the ignition leaving weird patterns on my scope and the alternator being as dead as dodo.
It would appear that the owner bought this car from a dealer who couldn't get it to run ...at a discount.
The alternator was possibly part of the cause of the bad start situation but having read a few threads here, I stipped the distributor to find the top ball bearing completely worn out. So worn in fact it has been chattering in the housing and worn a 1mm channel which would appear that the top of the shaft has been waving around.
The bearing is also brinneled to the point where there are marks in the housing which appear to have been made by the individual balls as they pass the pick up.
I couldn't find a replacement seal for the bearing so i have fitted a sealed type bearing which is 1.5 mm wider than the original (metric internal,SAE outer sizing) . i am maching the housing deep to fit the bearing but i am now thinking that perhaps it would have been better to go a size larger with OD of the bearing and rectify the wear.
Anyone have any thoughts on this?
Now regarding the alternator.
I have repaired the stator (completely open circuited) and basically restored everything in it. I could only find the three pin alternator reg on the car. From what i can see the series three only has this?
Does this mean there is no 6RA or 3AW relay on this model?
Cheers! Ron B.
Cheers! Ron B.
