#1 Does anyone have a knob like this?
Posted: Wed Sep 03, 2014 1:55 pm
by Lambo911
I have a strange knob! The one next to the ignition.
It isn't in the handbook and I'm not sure what it does, can anyone help please?
[img]
[img]http://i36.photobucket.com/albums/e21/r ... 0136d8.jpg[/img][/img]
Posted: Wed Sep 03, 2014 2:41 pm
by malcolm
Could be for girls to hang their handbags on? :D
Posted: Wed Sep 03, 2014 3:31 pm
Curry hook?
Posted: Wed Sep 03, 2014 4:25 pm
by andrewk
Does your horn work by pushing down on the steering wheel centre?
When I first got my car I had a separate "horn button" on the dash as the contacts on the steering column were broken.
From what I understand, the contacts on the column are a weak spot and when they would wear, the horn would sound when turning the wheel.
Posted: Wed Sep 03, 2014 7:19 pm
by Lambo911
Horn push still works on the wheel.
I'll do some investigation and try and chase the wires.
I'm guessing it's an after market knob then as opposed to a factory item.
Posted: Wed Sep 03, 2014 9:28 pm
by PeterCrespin
Certainly aftermarket but what is the action? I bet it's a pull-push that stays in either position, not a spring return push knob.
If so, look for reversing lights or some kind of fog light or even manual fan override. On open cars the right hand rocker switch is often used for this kind of thing but since yours is already spoken for by the fitted rear window heater the PO would have had to do something else.
Is this when you gleefully discover you have an overdrive manual box? :-)
Posted: Wed Sep 03, 2014 10:23 pm
by Lambo911
It's a weird dual action, clicks if you pull it out but has a sprung action if you push it.
I'm quite excited now to find out what it does!
Posted: Thu Sep 04, 2014 7:54 am
by ralphr1780
Probably the seat "Eject".
Posted: Fri Sep 05, 2014 12:37 pm
by Mountain King
Air Strangler?
but i think that is only on later zentih carbs.
#10
Posted: Fri Sep 05, 2014 12:48 pm
by Alty Ian
Check under the car for neon lights
#11
Posted: Fri Sep 05, 2014 3:30 pm
by Lambo911
The car has spent 16 years in Johannesburg South Africa so it could be some kind of anti-hijack control!
Would be cool to have side flame throwers !
#12
Posted: Fri Oct 10, 2014 8:18 pm
by JaggyWag
I think it might be a switch that prevents the operator from posting on this forum? Anybody else still wondering?
#13
Posted: Sat Oct 11, 2014 7:52 am
by Lambo911
Ha ha!
I haven't had any luck tracking down what it does yet. I can't easily get to the wiring. I will try again!
#14
Posted: Sun Feb 08, 2015 10:36 pm
by GravyGraham
Well, any luck? The suspense is killing us.
