#1 lead loading
Posted: Fri Dec 05, 2014 4:57 pm
Dear all, I am new to this forum and to E type ownership having recently bought a 1973 Series 3 E type DHC, and just started examining it properly and planning some improvements.
Upon close examination of the rear wheel arches I have found some rust on a horizontal line that runs from the back lower corner of the door to the rear arch- in other words I think this is the top of the outer sill.
I believe you should not be able to feel a ridge as you run your hand down the wing between the door and the arch but you can on mine.
Should this be lead loaded and be a completely smooth surface? I guess it was butt welded before lead loading at the factory.
I am now worried it has had a bodge over-sill repair slapped on perhaps in the eighties! I know the car has sat around since the late eighties in a dry garage and barely used.
Cheers many thanks for your help
Bob
Bob
