auto radiator and manual radiator differences
jivili
#1 auto radiator and manual radiator differences
Post by jivili » Fri Mar 13, 2015 6:09 pm
I have a good rad on my series 3 but I am changing from auto to manual and believe that the two rads are different
Anyone use an auto rad on a manual?
I don't have a manual rad to compare with so if someone has a brief explanation of the differences and if I can use it then I would appreciate it
SESH
Post by SESH » Fri Mar 13, 2015 10:32 pm
As far as I am aware the auto variant of the Radiator has a transmission oil cooler in the bottom of the rad.
Mike
1963 Triumph TR4 Signal Red
MarekH
Post by MarekH » Fri Mar 13, 2015 10:56 pm
If you look at the lower left side of the radiator, you'll find two small hosetails for the transmission oil cooler. You can track these back along the right hand lower side of the engine back to the autobox.
With a manual gearbox, you won't need these pipes and can simply remove them and use the rest of the "auto" radiator as a normal radiator.
