Does anyone know if a XJS Brake/Clutch pedal box will go into a Series 3??
Garry
XJS Brake/Clutch Pedal Box
AussieEtype
Topic author - Posts: 635
#1 XJS Brake/Clutch Pedal Box
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
Not even close. There are several different types depending on brake system but they are all huge and the base is at a steep angle. It won't even go on an XJ, never mind an E.
However, why bother? All E-type pedal boxes are the same after about 66 when the one-piece alloy version arrived. You just have to add the clutch pedal and master cylinder. It's already machined to accept them and there's a nylon spacer on the pivot shaft that you replace with spring and pedal.
AussieEtype
Thanks Pete - it is just I can get a XJS version really cheap and if it fitted I would use it.
Garry
Garry
