Power Steering Fluid
dooley1414
Topic author - Posts: 50
#1 Power Steering Fluid
Hi all I have a ex. US 1972 Series 3 V12 and was just wondering what was the best power steering fluid to get for it how much does the system take and is it the same fluid for the automatic gearbox? Many thanks in advance.... Des.
Ex. Texas Import 1971 Series 3 V12
Des. Suffolk.
Des. Suffolk.
#2 Re: Power Steering Fluid
ATF as for the autobox, capacity is small, less than a pint I think. Level adjustment is very sensitive due to the shape of the reservoir. A little at a time is best. I used a long rubber tube attached to the top of the ATF bottle to make it easier to avoid spilling it. Its not the easiest place to access, especially when hot.
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
S3 OTS & FHC
S1 FHC
XK140 FHC
#3 Re: Power Steering Fluid
Most anything will do that will service an older GM power steering pump, as , of course, that's what they are.
Enjoy,
Enjoy,
