itches eyes ..... smoke ?
christophe37
#1 itches eyes ..... smoke ?
Post by christophe37 » Fri Oct 02, 2015 5:46 pm
I'm french (sorry for my bad english)
In my V12, i have itches eyes and small odor...
no visible smoke....
i can't see the problem.
Have you a idea for detect the problem ?
regards,
Christophe
Quattrofrank
Norway
#2
Post by Quattrofrank » Fri Oct 02, 2015 6:56 pm
Its too rich mixture, you need to adjust mixture if possible
SESH
Post by SESH » Fri Oct 02, 2015 6:57 pm
Hi Christophe,
I had a similar problem with my series 3.
It was running too rich and the fumes were petrol vapour. However, do not discount problems with leaking exhaust gasses getting into the car.
Have the exhaust and manifolds checked for leaks and check the carbs are set up/tuned correctly.
I am sure others will be along to give other thoughts.
Mike
1973 Jaguar E Type Series 3 OTS Signal Red
1968 Proteus Jaguar C Type Ecurie Ecosse Flag Blue
1963 Triumph TR4 Signal Red
2020 Mustang Bullitt Highland Green
71 V12
Post by 71 V12 » Fri Oct 02, 2015 10:33 pm
Hi Chistophe,
The V12 relies on leak free sealing of the complete induction/ engine breathing system for correct fuelling. Any leaks will lead to rich running and a smelly exhaust.
Carefully check all engine breathing hoses including the large rubber breathing grommet at the front top of the left bank near the oil filler. Also the rubber blanking plug at the front of the right V.
There is no point adjusting carbs until you have ensured you don't have leaks.
I hope this helps,
Kind regards,
Kevin
D COUPE
Post by D COUPE » Sat Oct 03, 2015 11:43 am
Also check the oil leaking on to the exhaust balance pipe which could/will leak into any badly fitted tunnel.
DC
ITS NOT WHAT YOU DRIVE ITS HOW GOOD YOU LOOK IN IT
Post by MarekH » Sat Oct 03, 2015 12:22 pm
Dear Christophe,
You don't state whether you have a roadster or a coupe, nor when the problem occurs.
It is quite possible that what you are experiencing is exhaust gas fumes entering the cabin during normal driving. The exhaust gases are expelled from the engine at high pressure and there will be much lower air pressure in and around the bodywork of the car. This means that high pressure exhaust gases can be sucked into a low pressure region and if this is anywhere inside the car, then they will carry the symtoms you describe. This is possible even with a roadster.
The two main sources of "air leak" will either come from the engine bay itself, from a myriad of unsealed grommets and air vents (such as for the heater), or from the the rear of the car, where the exhaust and tailpipe's close proximity to the bodywork may allow for gases to be sucked into the boot and then into the main cabin. For example, the radio speakers at the B-posts have a direct path to the boot; the boot has various holes at the back by the bumper to the outside; the exhaust pipe exits very close to the bumper. It is very possible that at certain speeds, a pocket of low pressure air (a vortex) is created and exhaust gases soon find their way to the driver.
Whether the car is running rich or lean or leaking oil is mostly irrelevant, but it'd be more obvious if running rich.
Contrary to Kevin's advice, if the induction system has air leaks and these are after the throttle butterflies, this is likely to lead to leaner rather than richer running and typically would manifest itself mostly at idle, when the "extra" air will make up a higher proportion of the total air pulled into the engine. Air leaks, richness or leanness don't lead to itchy eyes - it is the fumes of one type or another getting into the cabin which are responsible.
You should be able to differentiate the smell of petrol vapour from exhaust gas vapour. The manual does have basic instructions for how to set the carburettors at idle. A hand held lambda sensor attached to a gauge would make a good diagnostic tool.
#7 Re: itches eyes ..... smoke ?
Post by PeterCrespin » Sat Oct 03, 2015 2:41 pm
christophe37 wrote:In my V12, i have itches eyes and small odor...
Does it smell electrical? Does it smell sweet like coolant?
Exhaust smells like exhaust and fuel smells like fuel so you need to give us an idea of the smell. On a Series 1 or 2 it could even be acid fumes from a boiling battery but on you car the battery and heater ducts are on opposite sides. However, the V--2s do have footwell ducts so if something is broken on the tubing or footwell connection, battery acid fumes could enter the car and someone may have messed with the 'adjustable' voltage regulator setting.
As for mixture issues, il faut toujours vous rappeler que d'un m?lange de carburant faible V12 utilise plus d'essence que d'un m?lange riche dans d'autres voitures - ?a pue aussi!
Sjmmarsh
Post by Sjmmarsh » Sat Oct 03, 2015 4:40 pm
Christophe
I had the same symptoms on the way back from Le Mans this year - it turned out to be a leaking manifold.
1973 S3 v12 2+2 1S52113BW
AussieEtype
Post by AussieEtype » Sat Oct 03, 2015 10:53 pm
Following on from what Marek said - when driving my OTS with the top down and side windows up, exhaust fumes do get sucked back into the cabin and is quite noticeable at higher speeds.
Having one or both side windows down tends to alleviate the problem.
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
Post by Heuer » Sun Oct 04, 2015 11:01 am
If we are talking about contaminated air in the cabin the likely cause is a) the fresh air duct seal not making full contact with the heater volute opening or b) missing bulkhead grommets. I had this problem on my FHC which I put down to lack of a grommet on the gearbox tunnel. After sealing that area there were still fumes reaching the cabin and a witness test (talcum powder on the seal) showed there was a gap between the seal and heater box with the bonnet closed thus drawing air in from around the engine.
christophe37
#11
Post by christophe37 » Mon Oct 05, 2015 6:02 pm
Thanks for you're answer ...
I check this points...
Christophe
christophe37
#12
Post by christophe37 » Sat Oct 10, 2015 6:28 pm
Today i make a race with my E-Type to the magny cours pist in France.
A lot people see a fire at the end to my exaust.....
I think may be it's same problem to the odor into the cabine
'to rich' carburation ?
How it is possible make correction (i have 4 new su carb) ?
(soory sorry for my very bad english)
regards,
Christophe
JEAN-LOUP
#13 Re: itches eyes ..... smoke ?
Post by JEAN-LOUP » Tue Oct 10, 2017 7:29 pm
Bonjour
J'ai un problème similaire sur ma V12 2+2
Avez-vous résolu votre fuite d'exhaust ?
Merci
Jean-Loup
