#1 Ecrou de roue bloqu?....Can't go out the whell
Posted: Sat Oct 24, 2015 7:52 pm
by christophe37
I have a problem to remove the whell (with 1 screw in the center)
Solutions ?
Je n'arrive pas ? d?monter l'?crou central sur une de mes roues (?crou central sur roue ? rayon).
J'ai tap?, chauff?, mis du d?grippant.....sans succ?s ....
Des id?es ?
Amities,
Christophe
Posted: Sun Oct 25, 2015 9:41 am
by Sjmmarsh
Christophe
It sounds like the spinner isn't moving. Are you using the brass fitting that goes over the spinner and the Thor hammer ?
I found that I had to hit it VERY hard to get it to move, but eventually it started to move a millimetre at a time.
You have to be brave if it is a rear wheel as the wing is in the way!
Posted: Sun Oct 25, 2015 11:07 am
Hi Christopher. ...look at the arrow to make sure you are undoing in the correct direction
Posted: Mon Oct 26, 2015 7:38 pm
by christophe37
Thanks for youre answers.
I use the brass system but now it's ko.
I buy a new for make a new test (i round in the good late).
Next step in few days...
Thanks a lot
