Oil Pump Modifications
panamacarrera
#1 Oil Pump Modifications
Post by panamacarrera » Mon Apr 01, 2019 10:11 pm
Hi All
My engine is being rebuilt. Just had this from the shop... “At sometime someone had die ground out the ports in your oil pump.” Anybody heard of this as a mod on the V12 engine? What benefit might it give?
Photo to follow tomorrow.
Cheers!
Nigel
'71 S3 OTS
panamacarrera
#2 Re: Oil Pump Modifications
Post by panamacarrera » Tue Apr 02, 2019 1:25 pm
Hi again
Here's a photo pf the modification we've found on my V12's oil pump...
Any ideas why someone would do this? For what benefit?
Cheers!
Nigel
'71 S3 OTS
#3 Re: Oil Pump Modifications
Post by christopher storey » Tue Apr 02, 2019 2:17 pm
The only thing I can think of is that it would/might reduce turbulence in the oil flow and thereby improve oil flow or possibly prevent cavitation , although AFAIK cavitation is more a problem with impeller type pumps rather than gear ones
#4 Re: Oil Pump Modifications
Post by abowie » Tue Apr 02, 2019 11:26 pm
As Christopher says to improve flow.
I've certainly seen this recommended and done in 6 cylinder oil pumps but I have no experience with V12 ones. I doubt it has done any harm.
panamacarrera
#5 Re: Oil Pump Modifications
Post by panamacarrera » Fri Apr 12, 2019 9:40 am
Thanks Chris & Andrew.
I've decided to go for a new oil pump. The car seems to have had oil supply problems in the past and this modified pump can't be ruled out as a culprit.
Thanks again guys
Nigel
'71 S3 OTS
