#1 Removing headrests
Posted: Fri Dec 18, 2015 5:09 pm
by Sjmmarsh
I am renovating the seats - the leather needs recolouring and the headrests needed replacement foam (the original foam had crumbled to the consistency of sand..).
I have managed to replace the headrest foam without removing the headrests, but can't get the staples in to finish the job as I can't get the headrests out of the seat. I've tried brute force (no joy) and sliding large zip ties down the side of the post to release the catch as the headrest is raised (still no luck).
It looks as if I am going to have to go in from the bottom of the seat back, but now that I have the seat out (easier than I thought) I can see the back and front of the seat are fastened to the other side by a row of panel pins.
Has anyone done this before? I am not sure whether it will be better to try and get the panel pins out and put it back together, or free enough of the back by cutting the back away from the pins and then stapling it back again once I have got the headrests out.
Any help would be appreciated.
Posted: Fri Dec 18, 2015 5:33 pm
by Gfhug
Hi Steve, I have had the fun of removing headrests from my S2 seats. If you search you may see other enquiries.
However, I had to open up the bottom of the seat back, unpick a few inches of stiching to get access to the stem from underneath. Then with hammer, long drifts etc. to lump it with managed to drive out the headrest.
Re-stitching the bottom of the seat where unpicked was pretty easy with proper curved leather/upholstery needles. Then hammer back in the tacks.
Not difficult to do.
What I then worked out is that by squeeing the thickness and/or width of the stem you can get it to slide freely up and down. Gently squeezing in a vice. Can't remember which way I had to do it, but that is the principle.
Posted: Sat Dec 19, 2015 12:05 am
by Sjmmarsh
Thanks Geoff
I think the S2 seats may be slightly different in construction. It looks like the cover was made like a pillowcase, pulled over the padding and frame and then tacked at the bottom by overlapping the front leather and rear vinyl. There is no obvious stitching to unpick.
I'll take a photo to show what I am working with.
Posted: Sat Dec 19, 2015 9:31 am
by Gfhug
Tacked at the bottom, but I had to undo a little of the stitching at the bottom of the side sections to get enough freedom to move the cover and get access to the headrest stem.
Posted: Wed Dec 23, 2015 3:50 pm
by Lambo911
I was told that there is a small tab on the headrest stem that you need to push in in order to get the headrest out. You didn't need to take the seat apart to do it.
could be part number BD36715
Posted: Wed Dec 23, 2015 5:18 pm
by rolando38
Mine were hard to remove, but finally with a simple lever actuated between the headrest and the seat, it came out
Posted: Wed Dec 23, 2015 10:14 pm
by Sjmmarsh
I can't find any release mechanism on my headrests. It would be lovely if there was one. Any ideas where it magistrate be located.
Rolando - leverage may work - did you protect the seat and headrest by levering between something like two pieces of wood? How much force did you need to apply?
Posted: Fri Jan 22, 2016 4:47 pm
by Sjmmarsh
I now have one of my headrests removed. This is how I did it:
1) removed seat from car - only needs 4 bolts to be undone.
2) with seat upside down and folded forwards, I unfastened the bottom of the seat - it is held in place with a line of short nails, which can be prized out with a screwdriver and needle nose pliers.
3) with all the nails out there is enough room to see the bottom of the headrest using a torch, but there is not enough room to get your hand and arm in. However all you need to do is to knock the piece on f Spring steel that is inside the bottom of the headrest column further inside the column. The headrest then just lifts straight out. I used a persuader (actually a pair of tree loppers) the fits inside the column, rested it against the spring steel and gave it a solid hit with a hammer. Job done!
I'll upload a photo of what the inside looks like so you know what you are dealing with! The clip exits the RHS of the column as you look at the seat from the front. The shape of the catch shows why these are so hard to move without opening the seat up.
Including putting the pins back in it only took me 30 mins.
Posted: Fri Jan 22, 2016 8:59 pm
by Sjmmarsh
Next question - does anyone know where I can get the tensioner springs that stop the headrest falling down? The part number is BD37599 but everybody seems to have no stock.
It must have been a common part for many headrests st the time, so is there an alternative?
#10
Posted: Mon Jan 25, 2016 11:54 am
by Sjmmarsh
I have found some of the springs at Norman Motors
http://www.normanmotorsltd.com. They have 3 left.
Posted: Thu Feb 18, 2016 11:28 pm
by GravyGraham
Interesting thread - I've recently replaced the foam and diaphragm in my drivers seat and the headrest now barely reaches The top of my shoulder! I'd like to get it to stay up but keeps sliding into the seat back.
#12
Posted: Thu Feb 18, 2016 11:39 pm
by Sjmmarsh
The spring as are easy to fit - I used a piece of cotton wrapped round the middle just in case it fell down into the back of the seat.
They cost ?5 each, plus vat and p&p, but there are only 3 left...
Posted: Tue May 17, 2016 9:34 pm
by jivili
Just reached this stage in my restoration and have been unable to source the springs as well
I used a length of 3 core pvc flex which is the same diameter as the springs @ 6.8mm od and it works a treat.
#14 Re: Removing headrests
Posted: Thu Feb 25, 2021 9:42 am
by Adamski
I know this is an old post but I'd thought I'd post my solution to the problem that came as a eureka moment.
One of my headrests was stuck in and all the force in the world wouldn't remove it. I got it to go up about 100 mm and then that was it. I figured that the clip was blocking it. I took the seats out as I was having the seat squab restuffed . The seat was dismantled. I carefully removed some of the nails holding in the upholstery at lower back. I was then able to insert a long length of flat bar up into the seat and locate it into the inside of the headrest oval tubular,keyhole surgery. I then whacked it with a hammer and this pushed the clip in. The headrest then came out. I have since removed the clips and stored them. There is a barb at the seat opening that is sufficient to hold the headrest in place
#15 Re: Removing headrests
Posted: Thu Sep 23, 2021 2:30 am
by hpage66
Likewise, I needed to remove the headrest on my series 2 OTS to replace the ratty covers. Wouldn't budge. Removed the staples from the base of the rear as others have described, opening it enough to get a look see with my trusty "torch". No spring steel clip was observed. The thing is apparently simply held tight in via friction.
A block of wood and a hammer, a few good whacks (more, actually then I thought would be necessary) and stem was at the base of keeper. Placed the seat upright, grabbed the headrest and it was out with a few good yanks.
50 year old staples were bent up and rusty, so simply used my Swingline stapler to refasten.
#16 Re: Removing headrests
Posted: Thu Aug 25, 2022 6:05 pm
by JoeLondon
Just for anyones info looking to replace headrest foams and, like me, not relishing the idea of removing the seats and getting fancy with needlework. I have just managed to replace both headrest foams on my S3 2+2 without removing the headrests.
Pull the headrests up, undo the 2 screws holding the plastic cover plate to the headrest, unpick the staples, replace the foams, staple the leather back - easier said than done, but simple.
You need a good strong upholstery stapler, not more than 80mm tall or so at the head, a stubby philips screwdriver or a 90deg drill driver attachment. I replaced the existing screws with larger threads to hold better.
I dont have a garage, everything done street side. My car is also a daily driver.
Seems the only thing that's not an engine out job on these things is emptying the ashtray
