The car has got a new top. I've tune the 2 doors and they can be closed with there window without problem.
I've buy a windscreen with the seal and I've tried 3 time to place the windscreen on the car. I've never been able to place it.
I cannot fix the seal on the upper corner. On the top, the opening of the car is too large. 5 mm larger then the windscreen.
I've decided to cut the old seal to better understand what happened.
Here a some pictures
On each side the windscreen does not follow the body :
Do I have to retrim it?
Can someone confirm me the opening dimension on the car? Mine is 130cm length between the down lower corner and in the middle of the opening the height is 57.5com.
Michel
