#1 XJS engine on the E Type
Posted: Wed Jul 13, 2016 6:22 pm
by MLBS3V12
Hi all,
I'm working on the XJS engine I will use on my e type.
I would like to have feedbacks from others who have use the same solution on their car.
I've a lot of questions without answers.
Thank you all.
Michel
#2 Re: XJS engine on the E Type
Posted: Wed Jul 13, 2016 7:45 pm
by PeterCrespin
MLBS3V12 wrote:Hi all, I've a lot of questions without answers.
Thank you all.
Michel
I've got a few answers without questions. Maybe you should ask some?
Mon chemin est trop court...
#3 Re: XJS engine on the E Type
Posted: Thu Jul 14, 2016 5:11 am
by MLBS3V12
Thanks Peter, I ll send you a pm.
Michel
#4 Re: XJS engine on the E Type
Posted: Thu Jul 14, 2016 7:32 am
by MarekH
Dear Michel,
Why don't you stick it on the forum and let everyone else benefit from the advice. For what it's worth, I am running an HE motor in my car and if you search on the jag-lovers.org site, you'll see plenty of answers (and pictures) to the questions you haven't posed.
#5 Re: XJS engine on the E Type
Posted: Thu Jul 14, 2016 8:22 am
by MLBS3V12
Hi Marek,
thanks for your remarks.
I'm going first to look at the jag-lovers.org site as you propose.
Am I right saying that you have chosen Megasquirt to manage your engine instead of the Jag ECU?
Michel
#6 Re: XJS engine on the E Type
Posted: Thu Jul 14, 2016 11:11 am
by MarekH
Yes, it's a MS3/3X, wasted spark and with four extra injector drivers to make up the full sequential twelve. The jag-lovers.org photos are a little out of date and only show a slightly outdated setup.
The principal changes are that the 36 minus 1 trigger wheel is cut into the crank pulley feeding a single VR sensor, the cam sensor is replaced with a Ford sensor, it has twin idle valves and a new custom built peak and hold driver box in the passenger footwell.
Other than that, the pictures should be a good guide.
See also pictures of Philip Lochner's etype (since sold) on the same site.
This is a batch fired MS2extra running twin 6cylinder EDIS units via a custom built box to fire the second six spark plugs 60' after the first.
