Brakes
Will Caradoc-Hodgkins
#1 Brakes
Post by Will Caradoc-Hodgkins » Mon May 25, 2009 7:04 pm
Took my car out for a cross London run to see daughter and after about an hour of stop go traffic my brake pedal kept going from normal to hard then i found that the brakes were binding?
Could also hear a hollow clunk sound from the near side servo when putting brakes.
I have fitted all new brake system some two years/5000miles ago.
I'm sure I read something about this phenomonon but cannt recall where.
After lettig her cool down brakes were back to normal so managed to get home.
Any thoughts on this would be appreciated.
Will
Aldeburgh
#2
Post by Aldeburgh » Thu May 28, 2009 12:09 pm
....."Took my car out for a cross London run to see daughter and after about an hour of stop go traffic my brake pedal kept going from normal to hard then i found that the brakes were binding?..."
Same thing was happening to my S3, and Harry has a similar but worse problem with his. He fixed mine but I cant remember exactly what he did with it... new servo or something. Seems a commonplace thing though.
'73 V12 2+2 Manual. I am on first name terms with every petrol pump attendant in the south of England.
Post by Heuer » Thu May 28, 2009 1:35 pm
If it is anything like the S1 system the servo is likely to be OK but the reaction valve on the end of the master cylinder may be suspect. This tends to fail and leave the brakes locked on. Are you having to top up with brake fluid? Any puffs of white smoke from the exhaust? If so it is going into the Reservac. Best bet would be to replace the entire master cylinder although I have no experience of the S3 so others may have a different view. Be aware it will eventually leave you stranded with the brakes locked on although you can release them by opening the bleed valve. Safer to get it fully checked over.
#4 Brakes
Post by Will Caradoc-Hodgkins » Sat May 30, 2009 10:38 am
Well got a new brake reaction valve repair kit,?20, from SNG so will fit today and see what happens.
We will see
