Good Afternoon All
need you help.
Looking to replace main looms under bonnet. ie from bulkhead under bonnet to main beam connector, getting some confusing info. Can someone please help.
I think I need the following
Forward Harness Engine
Bonnet Harness
Engine Harness
Fan Relay Harness
Aircon Harness
headlights connecting harness with plug
sidelights bulb holder and wire.
Do not need Bulkhead Harness
is this correct
thx
LHD 2+2 auto v12 with aircon wiring looms under bonnet
Nomisblue01
Topic author - Posts: 32
#1 LHD 2+2 auto v12 with aircon wiring looms under bonnet
E-Type Series 3 V12 LHD Auto
Alfa GTV Phase 3
Alfa GTV Phase 3
#2 Re: LHD 2+2 auto v12 with aircon wiring looms under bonnet
Hallo Simon
If you look at the Harnesses section of the Parts Manual and then the photographs of new looms from someone like Autosparks, I think you will answer your question.
Hope this helps
BTW did you buy from the Cheltenham guy in the end - any pictures?
Bob
Hope this helps
Bob
Bob
'71 S3
'71 S3
