MLBS3V12
Post
by MLBS3V12 » Sun Dec 04, 2016 6:47 pm
I’m going ahead on the engine from my S3. It is an XJS one. How do the crankshaft sensor can be fitted on the engine?
Who has done this adaptation and how has been done this particular fastening?
I’ve done a small flat angle bracket but the cable from the sensor is too close from the box oil filter. I’m not happy with.
Here is picture of the sensor:
Le chemin sera long!...
jagwit
Post
by jagwit » Mon Dec 05, 2016 10:45 am
Is that sensor for the Marelli ignition system?
If so, i think you would be better off using the dual coil Lucas ignition system.
Less complicated, also has vacuum advance, more reliable than Marelli.
Best Regards
Philip
