I have been in touch with Rory to arrange the return of his infamous 'threaded bar' tool. He has asked that I keep it, post this update and send it on to anyone who is looking to install an IRS soon.
So having fitted the rear 'V' blocks to the bodywork (tightly - difficult to get at these bolts once the unit is in place) and then loosely bolted up the IRS to these, the front V Blocks are invariably not aligned to the bodywork holes.
Rory's clever tool is attached to one of the rear ARB bolts and onto the front V Block. You them simply screw the nut down the shaft and it pushes the holes into alignment. Clever!
So from start to getting all 4 V Blocks aligned, bolted up and tight was literally 30 minutes for me. The Radius Arms were a different story!!
So if anyone has an IRS to be re-fitted then I strongly recommend you let me forward this onto you.
cheers
Ash
