4.2 Clutch cover measurement
Topic author - Moderator
#1 4.2 Clutch cover measurement
Hi All.....Im looking for a measurement for a 4.2 clutch cover...from the face where it mates to the flywheel to the face where it meets the release bearing.....im currently trying to mix and match covers and release bearings...thanks.. Steve
#2 Re: 4.2 Clutch cover measurement
Steve, is it an internal or external measurement you need?
I've a clutch and gearbox sat in the garage, do I need to remove the clutch from the gearbox and measure somewhere inside?
#3 Re: 4.2 Clutch cover measurement
Hi Geoff.....its the clutch cover that bolts to the flywheel......if you have one loose not bolted down its the measurement from the edge that touches the flywheel to the face that contacts the release bearing....so if you lay it on a flat surface and measure the depth if that makes sense...thanks..Steve
#4 Re: 4.2 Clutch cover measurement
Hi All..unfortunatly Geoff couldnt help...his clutch was bolted to the flywheel....so if anyone has one lying around and can help...thanks.... Steve
Doug Buchan
#5 Re: 4.2 Clutch cover measurement
Hi Steve,
I have one on the shelf and it measures 2-5/16" as per your specs.
Doug
Doug
Doug
'67 ots
'67 ots
