What causes plugs like THIS??
jagwit
#21 Re: What causes plugs like THIS??
Post by jagwit » Thu Apr 12, 2018 2:24 pm
Today, I took the car for a drive and then pulled a plug afterwards.
It looked perfect, no trace of that white powder. Coolant level had not changed from before the drive.
So I’m rather relieved!.
Best Regards
Philip
jagwit
#22 Re: What causes plugs like THIS??
Post by jagwit » Thu Jun 07, 2018 1:10 pm
Less than 1000km later and we have this:
Front of engine on the left, back of engine on the right.
I should add that I found the servo diaphragm was torn, every time the brakes were applied, huge amounts of unfueled air rushed into the intake manifold - right where the rearmost two cylinders draw their intake charge from.
Could it be that this is resulting from all that unfueled air entering the intake manifold behind the carbs closest to the bulkhead??
Best Regards
Philip
#23 Re: What causes plugs like THIS??
Post by Gfhug » Thu Jun 07, 2018 2:13 pm
Philip, where do you class cylinder 1 as being? Front or back of engine?
No 6 is at the front. Just might help us understand where you think this un-fuelled air is reaching.
jagwit
#24 Re: What causes plugs like THIS??
Post by jagwit » Thu Jun 07, 2018 2:27 pm
O heck!! Yes, then I've got my spark plug numbering wrong!! I'll fix it.
Best Regards
Philip
#25 Re: What causes plugs like THIS??
Post by Series1 Stu » Thu Jun 07, 2018 4:00 pm
Are you saying that replacing the servi diaphragm cured this problem?
jagwit
#26 Re: What causes plugs like THIS??
Post by jagwit » Thu Jun 07, 2018 4:54 pm
Nope, I'm saying it's the only and most likely cause for the plug's condition found thus far.
Obviously, I'm fixing the membrane and THEN I'll be keeping an eye on the plugs. IF the plugs THEN remain good, the conclusion will be that the broken membrane caused the plugs to become fouled as per the pics.
Best Regards
Philip
jagwit
#27 Re: What causes plugs like THIS??
Post by jagwit » Sat Jun 09, 2018 8:51 am
Another observation which might be relevant in this instance. The RH exhaust (which serves the rear three cylinders) appears to be burning more grey than the left one.
Best Regards
Philip
jagwit
#28 Re: What causes plugs like THIS??
Post by jagwit » Fri Dec 21, 2018 11:38 am
Update:
This car has now been driven quite a bit since doing all this work and the plugs are no longer fouling as per post #1.
I am now convinced that the vacuum leaks were the main cause of the plugs manifesting like this.
Best Regards
Philip
