I'm about to modify the back brakes on a 1967 E-type, I'll fit vented disks using Rob Beere's kit.
Does anyone know if it's possible to fit later calipers on an early differential?
James
Later brakes - early differential
#1 Later brakes - early differential
James 67 OTS, 73 OTS 6.0L, and other makes
#2 Re: Later brakes - early differential
I have Series 2 calipers on my Series 1 final drive unit. I did cut away parts of the cage to give future access for pad changes etc.
I can send pictures if you want.
#3 Re: Later brakes - early differential
#4 Re: Later brakes - early differential
Ok. Will do but I'm away until the weekend.
