spare keys.
PAN4213
#1 spare keys.
Post by PAN4213 » Wed Aug 15, 2018 9:41 am
hi all,
my e-type just arrived from the US.
However the ignition key does not fit the door lock!
Appears that the ignition barrel has been replaced very recently and the door locks, are to be original.
if locks original how can I obtain replacement key?
No jack present. best source for jack?
many thanks.
S2, 2+2, 1969
#2 Re: spare keys.
Post by Heuer » Wed Aug 15, 2018 9:56 am
It would be good if you added the Series and year of your car to your signature to enable members to better offer advice. There are two types of ignition lock, two types of door locks and about and three types of jack all depending on what your car is FHC/OTS/2+2 and year. And please don't double post the same questions!
PAN4213
#3 Re: spare keys.
Post by PAN4213 » Wed Aug 15, 2018 10:04 am
apologies.
Series 2. 2+2. FHC. Nov 1969.
many thanks in advance.
S2, 2+2, 1969
#4 Re: spare keys.
Post by Heuer » Wed Aug 15, 2018 10:30 am
It is either a FHC or a 2+2, can't be both. Jaguar called the short wheelbase two seat hardtop car a 'Fixed Head Coupe' and the longer bodied car with four seats the 2+2. The FHC has the door locks in the handles whilst the 2+2 has them in the door skin. The 2+2 has a different jack to the other cars (the locating shoe) but you need to confirm the cills have not been replaced and the location sockets lost. It was originally made by Metallifacture andshould look like this:
Ebay is your best bet. As for door/ignition locks suggest you try SNGB or Hutsons. There is an illustrated parts catalogue in the Forum KB or on the SNGB web site.
PAN4213
#5 Re: spare keys.
Post by PAN4213 » Wed Aug 15, 2018 10:51 am
hello David,
many thanks.
its a 2+2. but the locks/barrel are within the handle i.e. not separate in the door skin.
I will check the names you recommended.
thanks again.
Series 2. 2+2.1969.
S2, 2+2, 1969
tim wood
#6 Re: spare keys.
Post by tim wood » Wed Aug 15, 2018 11:41 am
Hi, if you want original( I.e not new keys cut from blanks) the a few sellers on eBay have these. Assuming that you have the key number. If you don’t have the number then I think it’s a case of taking the locks out where the key number will be married.
Tim
#7 Re: spare keys.
Post by mgcjag » Wed Aug 15, 2018 11:51 am
Hi ...whats your name...please try to put it in with your car year/model.....my 69 S2 2+2 has different keys..in the photo the longer is the ignition...the center is the door key....this has also been mentioned in you other post asking the same question....the door key fits into the push button in tne door handle.....Steve
PAN4213
#8 Re: spare keys.
Post by PAN4213 » Wed Aug 15, 2018 12:31 pm
Hello Gents,
re; key.
Am happy with a 'new' replacement key. Once I obtain ref nr from lock area does anyone know whom I should then approach ?
I assume quoting the VIN nr alone will not suffice?
Bill.
S2. 2+2. 1969.
S2, 2+2, 1969
#9 Re: spare keys.
Post by Gfhug » Wed Aug 15, 2018 12:50 pm
Bill, if you find the key number, typically starting FS, e.g. FS923, then any decent locksmith will cut brand new keys from that code. One warning is that with age the lock itself may have worn to the extent that a correctly cut key from the code will not work smoothly. I suggest you take the lock barrel with you and they can check as they go. I'd suggest finding a decent locksmith not a highstreet cobbler 'we can cut any key' merchant.
Edited to add: You might be lucky just quoting the number and getting a good fit, save taking the lock out, only doing that if needed should it not work.
PAN4213
#10 Re: spare keys.
Post by PAN4213 » Wed Aug 15, 2018 1:03 pm
Cheers Geoff.
S2, 2+2, 1969
S2, 2+2, 1969
