Squeaky chattering noise front of engine
AnD3rew
#1 Squeaky chattering noise front of engine
Post by AnD3rew » Sun Aug 19, 2018 2:00 am
Hi all
Today out of nowhere I was getting a rotational chattering squeaky noise coming from the front of my motor, it doesn’t seem to be or sounding like a slipping belt. I suspect pulley or pump bearings what are your thoughts?
It mostly went away after about 20 minutes although there is still an ocassional chirp. I would like to think it’s just gone away for good, but pretty sure that’s wishful thinking?
4.2.
Sydney Australia
Current
Jaguar Red Series 2 2+2 XKE 1969
Jaguar Italian Racing Red F-Type S 2014
Jaguar XJ6 Vanden Plas dark green 1985
Jaguar XJS V12 Silver 1987
Previous of interest
Jaguar XJ6 Sovereign series 3
MGA 1959
#2 Re: Squeaky chattering noise front of engine
Post by abowie » Sun Aug 19, 2018 2:05 am
Belt tensioner would be my first port of call.
AnD3rew
#3 Re: Squeaky chattering noise front of engine
Post by AnD3rew » Sun Aug 19, 2018 6:54 am
Thanks, in the sense that you think it needs retensioning or that might be what is causing the noise?
Sydney Australia
Current
MGA 1959
ALAN COCHRANE
#4 Re: Squeaky chattering noise front of engine
Post by ALAN COCHRANE » Sun Aug 19, 2018 9:02 am
Andrew
No the tensioner, if it's the culprit will need to be replaced. Many owner's including me have removed the tensioner because it's noisy at the best of times and if you re-tension the fan belt using the alternator, is not actually needed.
Alan
Alan Cochrane
AnD3rew
#5 Re: Squeaky chattering noise front of engine
Post by AnD3rew » Sun Aug 19, 2018 10:55 am
Nice, will look at that thank you.
Sydney Australia
Current
MGA 1959
andyf
#6 Re: Squeaky chattering noise front of engine
Post by andyf » Mon Aug 20, 2018 4:08 pm
I have a similar noise! I thought it might be water pump, but this post got me thinking that it could be the tensioner! There is slight movement in the water pump pulley but I am not losing water and no other signs of wear. Is there a simple check to ascertain which, before I spend over £400 having a new pump fitted. Is it relatively simple to remove or bypass the tensioner? I assume a different length belt would be required?
Andy '69 Series 2 2 plus 2
#7 Re: Squeaky chattering noise front of engine
Post by christopher storey » Mon Aug 20, 2018 5:34 pm
If you push the tensioner in and lever the belt off it , it is then easy to spin the tensioner pulley by hand. If it is stiff, notchy, or noisy in rotation then it is highly likely that it is the culprit. At the same time, whilst you have the belt off, you can do a similar test on the water pump . I have to say, however, that if there is any play in the pump pulley , it does not bode well for its future
#8 Re: Squeaky chattering noise front of engine
Post by mgcjag » Mon Aug 20, 2018 6:20 pm
Hi Andy....you have a 2+2 same as me......i had this type of noise turned out to be the alternator....looking side on the pully was not in line with the waterpump or crank pully......there was a small spacer missing from the adjustable bracket and the alternator not spaces up properly.....worth checking....Steve
AshM
#9 Re: Squeaky chattering noise front of engine
Post by AshM » Tue Aug 21, 2018 6:38 pm
As suggested - mine was a completely shot tensioner pulley.
Replaced with the SNGB Stainless Steel equivalent and it’s like a Rolls Royce purr. I wish... :bigrin:
Ash
Series 2 FHC 1970
1R 20607
AnD3rew
#10 Re: Squeaky chattering noise front of engine
Post by AnD3rew » Tue Sep 18, 2018 1:07 pm
Turns out it was a completely shot alternator, eventually bearings seized and belt was squealing over the pulley. Now replaced with a brand new Lucas alternator and all good.
Sydney Australia
Current
MGA 1959
