S1 Door latch
DAVID.XK
#1 S1 Door latch
Post by DAVID.XK » Sun Jan 27, 2019 11:22 am
I could do with some help with my S1 offside door latch. On opening the door from fully shut, the lock cylinder button went in but did not Spring out as it should. It will pull out but not Spring back as it should. Now the door will only partially shut (on the first tooth of the latch cog) and not stay fully shut. Tried adjusting b post plate but makes no difference.
Have removed the latch but not sure what to look for. Can't see any obvious adjustment. Any knowledge here would be great!
David Skeels
1962 Series 1 3.8 FHC
1973 Jenen Interceptors Mk3
1973 MGB
mark10337
Switzerland
#2 Re: S1 Door latch
Post by mark10337 » Sun Jan 27, 2019 3:45 pm
sounds like the spring inside the casing. either the spring has broken or has snagged. Further careful dismantling will show what is wrong.
-Mark
