Ultrasonic cleaner
#1 Ultrasonic cleaner
So I got tempted and bought one after seeing a friends. Plan is to strip and clean the carbs but I did a first experiment using it to clean the grime off the reverse light lens and rear lights....45 deg C with some detergent....amazing. The grimy reverse light lens looked like new in 3 mins....early days but very promising
#2 Re: Ultrasonic cleaner
Hi Julian...more details please...what have you got..size...link....thanks...Steve
#3 Re: Ultrasonic cleaner
This is the cleaner
This is the detergent.
although you could probably use washing up liquid. 6 litre tank so big enough for carb bits methinks. The supplied main lead was awful - earth pin fell off after first use - but the unit itself has a standard IEC type connector and so far seems fine. Yet to try the carburettor parts (too cold to face getting them off the car) but I tried the plastic lens's and it was amazing.
Mark Gordon
#4 Re: Ultrasonic cleaner
The real advantage to ultrasonic cleaners is that they clean areas that are nearly inaccessible as long as you can get the immersion liquid into the tiny crevices and passageways. When you turn it on, you can watch the gunk just dissolve and float away from the dirty part.
#5 Re: Ultrasonic cleaner
INVISIBLE PICTURES
Jerome Lunt
2008 MX-5 NC PRHT - now gone
#6 Re: Ultrasonic cleaner
I can see them.....try another browser? Thats all i can offer unfortunatly....im not good with computers/systems..if they dont have carbs im lost
#7 Re: Ultrasonic cleaner
I can't see them either.
But here's a trick:
Quote the whole post as if to reply... now you can see the urls of the images. Right click, open in new tab, cancel the reply, job done.
But here's a trick:
#8 Re: Ultrasonic cleaner
David,
What is going on here? I still cannot see the pictures/links and cannot see the link posted by rswaffie (Richard) in his latest restoration update.
I'm using Firefox, fully updated. Invisible in IE and Chrome.
JagWaugh's trick works but that's not the point.
Thanks.
Thanks.
Jerome Lunt
#9 Re: Ultrasonic cleaner
Hi Jerry....suggest you pm David.....incase he dosnt see your post above..ps just tried firefox on a tablet and works ok for me....Steve
#10 Re: Ultrasonic cleaner
All the photos show for me. The links cactusman put up are to Amazon product pages and auto embed into the post. Try going to the bottom of the page and clicking on 'Delete all Board Cookies', exit browser and try again.
#11 Re: Ultrasonic cleaner
It just dawned on me.
The reason they weren't showing for me was that I run an adblocker. I just turned mine off, and now the links show.
#12 Re: Ultrasonic cleaner
Deleted cookies did not sort that.
Turned off my Kaspersky AV made no difference.
Turned off Kaspersky AV and re-started the laptop made no difference. I still do not see those Amazon links. I do not have an ad blocker (other than the Kaspersky) installed.
Jerome Lunt
