replacement coil for SNG Re-Opus ignition
JJC
#1 replacement coil for SNG Re-Opus ignition
Post by JJC » Fri Feb 15, 2019 2:24 am
You chaps have a preferred high performance replacement coil for the 1973 E Type with Updated SNG equipment ? I would think there are a few coils out there that would work.
JJ
lowact
#2 Re: replacement coil for SNG Re-Opus ignition
Post by lowact » Fri Feb 15, 2019 12:49 pm
My understanding, the SNG ignition is not Re-Opus, it is a Jaguar CEI ignition system shoe-horned into Opus amplifier casing and distributor body? That the distributor to use with CEI ignition is part # DAC6093?
JJC
#3 Re: replacement coil for SNG Re-Opus ignition
Post by JJC » Fri Feb 15, 2019 2:38 pm
Many thanks for getting back. However, looking for just the coil. Tried the DAC # you suggested, but no luck .
JJ
lowact
#4 Re: replacement coil for SNG Re-Opus ignition
Post by lowact » Fri Feb 15, 2019 10:56 pm
I should retract that comment as i don't know enough about the sng conversion. Has ballast resistor but unlike Opus doesn't need it? So is it just fake for looks? If it DOES need it then maybe the special low resistance coil needed also ....
JulianBarratt
#5 Re: replacement coil for SNG Re-Opus ignition
Post by JulianBarratt » Mon Feb 18, 2019 7:58 am
The coil that we use in our V12 ignition conversions is part number C34736.
https://www.sngbarratt.com/uk/#!/Englis ... ca1668cedd
Hope that this helps
MD at SNG Barratt Group
