Just located the first wishbone inner fulcrum shaft. Quite fun getting all the washers lined up
Plenty of grease plus a couple of 15mm dowels as dummy shafts really help...you can to and fro them as you fit everything
Also one end had less space due to springyness of cage so it was easier to get all the washers in this end first, the other end was then much easier.
One down, one to go
Robbie
