Phone / sat nav adaptor
dale bowman
Topic author - Posts: 20
#1 Phone / sat nav adaptor
Has anyone ever seen of found an adaptor that will go into a positive earth cigar lighter and allow a normal phone / sat nav connection. Just thought it was worth a shot before I add a 12v connection under my dash.
Cheers D
Cheers D
1964 series 1 3.8 fhc
There are three types of people in this world.
Those who can count and those who can't.
david.coan
#2 Re: Phone / sat nav adaptor
I am pretty sure no such adaptor will exist. Why not convert the car to negative earth, or try powering the satnav from a mobile phone external rechargeable power pack. When you say install a 12v socket, do you mean another cigar lighter fitting but wired for negative earth? If you do you would need to mount it in an insulated box ( plastic ) to ensure no metal bodywork could ever touch the new socket and think carefully about fusing arrangements . I think the perceived wisdom is dont do it, don't run negative earth devices like radios or satnavs in a positive earth car, just not worth the risk. Ask an auto electrician to quote you to install it, if he refuses you know then its not a good idea.
David
#3 Re: Phone / sat nav adaptor
This is not difficult. Cheapo USB sockets can be found on your favourite online resource. Also obtain a plastic switch mount. Plastic is important as it matters not whether the frame is +ve or -ve. I’ll take a photo of my installation later.
#4 Re: Phone / sat nav adaptor
Simply mount either a lighter socket or USB connector into the cubby hole and you can decide which polarity you want; it is made of fibre board so electrically isolated. More info here: http://forum.etypeuk.com/viewtopic.php?p=721#p721
#6 Re: Phone / sat nav adaptor
Hi Dale......this could be of interest......http://www.mossmotoring.com/negative-gr ... round-car/ or far simpler to just reverse the pos/neg wires in the fly lead that you will plug into the socket....... Steve
#7 Re: Phone / sat nav adaptor
“I’ll take a photo of my installation later.”
David beat me to it.
dale bowman
#8 Re: Phone / sat nav adaptor
Cheers Guys, lots of ideas here. Swapping the leads … such a simple idea, never thought of that … must be an age thing :-)
#9 Re: Phone / sat nav adaptor
Bear in mind you cannot just swap the leads on the standard lighter socket as the case is earthed through the console. You could replace it with one of the plastic bodied ones though but the auxiliary socket in the glove box is the best solution, not least because as you change gear you will knock the Sat Nav plug out of the console cigar socket; this invariably happens just when you need the directions!
#10 Re: Phone / sat nav adaptor
The auto electrician who sold me my car 16 years ago gave me a male plug cross wired to a female socket on a very short lead. It has worked for emergency phone charging, but I will be switching my cars polarity over on restoration.
Cheers,
Glenn
Cheers,
Glenn
#11 Re: Phone / sat nav adaptor
Has anyone installed a power supply that actually charges a sat nav using a cable and not the one that comes with the unit (ie the one that plugs into the cigar lighter)?
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
dale bowman
#12 Re: Phone / sat nav adaptor
Again ... never thought of the 'knocking out' when changing gear. God I'm getting old. Curious about the earthing though. If the cigar lighter is earthed through it's body via the gauge / switch panel, why does it have two leads ?. I assumed, rightly or wrongly, that one was positive earth and the other was neg supply.Heuer wrote: ↑Sun Mar 03, 2019 12:19 pmBear in mind you cannot just swap the leads on the standard lighter socket as the case is earthed through the console. You could replace it with one of the plastic bodied ones though but the auxiliary socket in the glove box is the best solution, not least because as you change gear you will knock the Sat Nav plug out of the console cigar socket; this invariably happens just when you need the directions!
But in any case will go with the additional glove box socket. Thanks David
Dale
#13 Re: Phone / sat nav adaptor
This is my setup. All my satnavs have USB leads which allows me to have satnav and phone plugged in while driving. This unit is approximately the same size as the ash tray, and slots into that hole when I'm touring. Not a lot of use for the smokers among us.........
Wired into the fused side the appropriate fuse it is only hot when the ignition is on. All components were bought online.
#14 Re: Phone / sat nav adaptor
Thanks Chris, I'll see if I can find the same on line.
61 OTS 875047
61 OTS 875047
#15 Re: Phone / sat nav adaptor
I used the installation kit of a Garmin Zumo designed for Motor Bikes (rainproof and "take the most beatiful/curvy route"). This kit comprises an antenna (for traffic information to be hidden under the dashboard or at the bottom of the windscreen) and a pair of cables you fix to + and -.
The other end of this cable set is one cable with one plug coming up from the hole in the front center of the dashboard next to the mirror-rod. So if there is not SatNav, all you see is just a short black cable with a relatively small plug laying on the dashboard. Plug it in the SatNav, it has power and Antenna.
Happy driving!
Happy driving!
Ser. 1.5 DHC LHD
#16 Re: Phone / sat nav adaptor
