IRS rebuild
Robbiee
#1 IRS rebuild
Post by Robbiee » Sun Feb 24, 2019 7:20 pm
Hi All
Just located the first wishbone inner fulcrum shaft. Quite fun getting all the washers lined up😬😬
Plenty of grease plus a couple of 15mm dowels as dummy shafts really help...you can to and fro them as you fit everything
Also one end had less space due to springyness of cage so it was easier to get all the washers in this end first, the other end was then much easier.
One down, one to go
Robbie
#2 Re: IRS rebuild
Post by mgcjag » Sun Feb 24, 2019 7:45 pm
Hi Robbie...looking good.....check out your grease nipples......usually they are straight and not 90deg so that you can access them through the holes in the irs base plate....Steve
Robbiee
#3 Re: IRS rebuild
Post by Robbiee » Sun Feb 24, 2019 9:39 pm
Hi Steve
Will do thanks
Robbie
Robbiee
#4 Re: IRS rebuild
Post by Robbiee » Sun Feb 24, 2019 10:21 pm
Hi Steve
You’re quite correct for the later cover plate, however mine is early ‘62 and has the early cover.
It has a larger central access hole and is cut away where the grease nipples are. The grease nipples were 90 degree ones pointing outwards see my photo.
It’s all in the detail😊
Regards and thanks for pointing it out
Robbie
Robbiee
#5 Re: IRS rebuild
Post by Robbiee » Wed Feb 27, 2019 8:39 am
All washers etc in place
That was fiddly...needed 3 hands
Robbie
#6 Re: IRS rebuild
Post by mgcjag » Wed Feb 27, 2019 9:12 am
Hi Robbie....looking great.....is it ready to go back in......Steve
Tom W
#7 Re: IRS rebuild
Post by Tom W » Wed Feb 27, 2019 11:05 am
Looks very nice. I did mine last summer, you’re right, getting everything to line up is very fiddly.
One point, are the nuts securing the discs the correct locking nuts? I see they need to come off again as the driveshafts aren’t installed. They should be locking nuts, but aren’t nylocks, as nylocks don’t like the heat from the brakes.
Tom
1970 S2 FHC
Robbiee
#8 Re: IRS rebuild
Post by Robbiee » Wed Feb 27, 2019 11:47 am
Hi Steve/Tom
Got to do hub carriers and drive shafts and attach shockers and radius arms
The nuts are temporary with some domed spacers just to hold everything in place and get the discs centralised and callipers shimmed. I have locking nuts ready but I won’t do these until the car is in it’s wheels and the spacers set up!
BTW. I’m struggling a little with getting a couple of the circlips to sit in their grooves properly on the drive shaft UJs ...I guess it’s because the bearing cups need pushing in a tiny fraction more? I worry about making the UJs a bit stiff but I guess they free up with a bit of use?
Am I correct?
Any views
Robbie
#9 Re: IRS rebuild
Post by mgcjag » Wed Feb 27, 2019 1:22 pm
Hi Robbie.....are you useing the original style circlips....if so have a close look at one they look like they have been stamped out so slight round edge on one side and flat on the other...i found that fitting them with the flat side to the uj fitted best..i didnt like the new ones that came with the uj,s they didnt seem to fit very well.....Steve
Robbiee
#10 Re: IRS rebuild
Post by Robbiee » Wed Feb 27, 2019 1:55 pm
Good plan
Jeremy
#11 Re: IRS rebuild
Post by Jeremy » Wed Feb 27, 2019 10:39 pm
I had the same problem. Those new circlips are definitely thicker than the old ones. I ground them down slightly to get them to fit.
Jeremy
1967 S1 4.2 FHC
44DHR
#12 Re: IRS rebuild
Post by 44DHR » Thu Feb 28, 2019 9:40 am
Yes,
when installing a circlip, check each face as when they are stamped out there is a smooth face and a slightly rounded face due to their production.
The smooth face of the clip should always be installed towards the item it is retaining - i.e. against any force trying to push against the clip.
https://en.m.wikipedia.org/wiki/Circlip ... p_Ring.jpg
Dave Rose
1967 Series 1 4.2 FHC
Robbiee
#13 Re: IRS rebuild
Post by Robbiee » Thu Feb 28, 2019 11:12 am
Thanks Dave
I learn every day!
BTW my 62 Coupe has 799DHR numberplate!
Robbie
Robbiee
#14 Re: IRS rebuild
Post by Robbiee » Sun Mar 03, 2019 9:00 am
Has anyone fitted a remote bleed system for the rear brakes?
If so , any opinions on whether to self fabricate or buy a bespoke (eg Fosseway) system?
Advice would be appreciated
Robbie
#15 Re: IRS rebuild
Post by mgcjag » Sun Mar 03, 2019 9:07 am
Hi Robbie.....made up my own....sorry dont have a photo....not a pretty as a Fosssway but not something i look at..been on the car 10 years no problems....just used cunifer pipe and a few fittings bleeds are fixed to the bottom of the cage...so not a flexi system but it dosent need to be....Steve
#16 Re: IRS rebuild
Post by Gfhug » Sun Mar 03, 2019 9:56 am
Robbie, I've fitted the Fosseway remote bleed kit. Easy to fit and use. It'll come down to you deciding how much fabrication you want to do.
Robbiee
#17 Re: IRS rebuild
Post by Robbiee » Sun Mar 03, 2019 10:04 am
Thanks gentlemen
Robbiee
#18 Re: IRS rebuild
Post by Robbiee » Sun Mar 03, 2019 10:07 am
Here’s a further shot of my IRS
Shockers might be a little too blue but probably ok with a bit of dust/road dirt on
Robbie
Robbiee
#19 Re: IRS rebuild
Post by Robbiee » Sun Mar 03, 2019 10:12 am
Oops here you go
Jeremy
#20 Re: IRS rebuild
Post by Jeremy » Mon Mar 04, 2019 9:47 am
Super job Robbie. Hope you were more successful than I was in getting the bearing preloads and endfloats correct... :scratchheadyellow:
+1 for the Fosseway bleed kit
Jeremy
1967 S1 4.2 FHC
