Rear shock absorber bolts
Malc
#1 Rear shock absorber bolts
Post by Malc » Tue Mar 05, 2019 10:52 pm
Now I know that this has been mentioned before but I can’t find it. This is probably a stupid question but I assume that the rear shock absorber bolts go in from the rear with the nut at the front to allow removal in the future, if necessary, without having to remove the whole IRS. I’ve done all the rear suspension, and very nice it looks too, just putting the rear shocks on before heaving it into place - a job I am not looking forward to even with a few helpers!
Malc
Series 1 2+2, 1968 Blue exterior, grey interior
#2 Re: Rear shock absorber bolts
Post by abowie » Wed Mar 06, 2019 12:31 am
Bolt goes in from the inside with the nut at the back, which is opposite to what you have said above.
There is often not enough clearance to get the bolt out otherwise if you want to remove the rear shocker depending on exactly what car it is. Even getting a spanner on the nut can be hard in a 2+2.
Robbiee
#3 Re: Rear shock absorber bolts
Post by Robbiee » Wed Mar 06, 2019 6:20 am
If you mean rear shockerS (plural) then the answer is that the NUTs go on the outside of the irs frame and the bolts pass from inside to out ie the rearmost goes backwards and the front most goes forwards
Robbie
ChrisC
#4 Re: Rear shock absorber bolts
Post by ChrisC » Thu Mar 07, 2019 10:51 am
Agree wit Rob :) nuts on the outside.
1964 FHC 4.2
Malc
#5 Re: Rear shock absorber bolts
Post by Malc » Fri Mar 08, 2019 2:20 pm
Thank you all - I’ve had another look it’s all pretty apparent really. I was obviously remembering things wrong Thanks again.
Malc
