It's not a safety issue as the shaft cannot come undone but the play is more than I would expect. Obviously it needs some movement or one could tighten the shaft to the point where the pedal would not function but just seems quite excessive to me.
Maybe just over-analysing as there was not a spacer before and the accelerator linkage presumably just self-centres it but would value any thoughts.
If someone could check whether they have similar play that would be much appreciated.
thanks
Ash
