Oil pressure gauge replacement
Spark
#1 Oil pressure gauge replacement
Post by Spark » Sat Mar 30, 2019 1:58 pm
Hi all
E type series 1 2+2
I’m replacing the electrical oil pressure gauge with the capillary type
What do I do with the wires which connect to the current gauge ( lamp obviously stays)
Can they simply be made safe or do I need to do something different
Thanks in advance
Moeregaard
#2 Re: Oil pressure gauge replacement
Post by Moeregaard » Sat Mar 30, 2019 2:08 pm
Just put some heat-shrink tubing over the ends, to cover the metal connectors, and stow them safely. I wouldn't cut them off, in the event some future owner of your E-Type decides to refit the electrical gauge.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
Spark
#3 Re: Oil pressure gauge replacement
Post by Spark » Sat Mar 30, 2019 2:27 pm
Brilliant
Thanks for the speedy reply
cdaubs
#4 Re: Oil pressure gauge replacement
Post by cdaubs » Wed Apr 10, 2019 4:49 pm
Phill,
I have a '64 and have been thinking of doing the same gauge replacement. Which gauge did you go with? I sourced a Smiths one, but haven't done the change over yet.
Thanks,
Charlie
Charlie Daubs
'64 FHC #890093
Spark
#5 Re: Oil pressure gauge replacement
Post by Spark » Sat Apr 13, 2019 10:31 am
I bought a gauge kit from MandC Wilkinson
Smiths gauge and all the connections included
Fitted really easy
#6 Re: Oil pressure gauge replacement
Post by Heuer » Sat Apr 13, 2019 1:09 pm
64etype
#7 Re: Oil pressure gauge replacement
Post by 64etype » Sat Apr 13, 2019 3:45 pm
Problems have been reported with the "new" mechanical "Smiths" 0-100psi gauges sold by the usual suppliers. I returned the unreliable unit I had purchased and found a used 0-60 mechanical gauge from a Lotus Europa. It looks identical to the original electric item after exchanging the chrome bezel for the black one.
Eric
#8 Re: Oil pressure gauge replacement
Post by mgcjag » Sat Apr 13, 2019 4:28 pm
Hi Eric.....what problems......i have one on the shelf waiting to fit...thanks....Steve
tim wood
#9 Re: Oil pressure gauge replacement
Post by tim wood » Sat Apr 13, 2019 6:21 pm
I would be interested to know where you located a 60psi mechanical gauge. I've been seeking one for a while. I've fitted the commonly available 100psi unit but a 60psi gauge would improve the appearance somewhat.
tim
64etype
#10 Re: Oil pressure gauge replacement
Post by 64etype » Sun Apr 14, 2019 12:18 am
mgcjag wrote: ↑
The one I had would stop at about 20 psi until pressure in the engine built to 40 or 50, and then it would jump to maybe 30. I knew it was wrong because I had previously attached a spare mechanical Stewart Warner gauge directly at the oil port on the filter block when I was trouble shooting problems with the electric unit and sender. All quite disconcerting during the first start of a newly rebuilt engine. After I removed the 0-100 indicator I plumbed it to my air compressor and steadily increased the pressure to 80. It never showed more than about 30. The vendor took it back and made a refund. I found the Europa gauge on Ebay (U.S.). It typically pegs on a cold engine start and then settles in at about 50 psi at cruise when the oil warms. It's very reassuring watching the actual pressure move around without the lag in the electrical unit.
Eric
Zei220
#11 Re: Oil pressure gauge replacement
Post by Zei220 » Sat Oct 09, 2021 5:53 pm
Just found the gauges are available from Smiths.
https://www.smiths-instruments.co.uk/jaguar/e-type
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
#12 Re: Oil pressure gauge replacement
Post by malcolm » Sun Oct 10, 2021 8:36 am
I have the 0-100 one from SNG, works perfectly and never had any problems. Checked against a pro unit and readings identical at all revs. Eric obviously had a duff one.
