Series 2 aesthetics
Herzeg
#201 Re: Series 2 aesthetics
Post by Herzeg » Tue Feb 12, 2019 9:53 am
Hi Marek
I have your original led reversing lights. Are you able to swap out those for the new ones, or do you need to replace the whole unit?
MarekH
#202 Re: Series 2 aesthetics
Post by MarekH » Tue Feb 12, 2019 1:26 pm
The new boards are a press fit into the clear Lotus bit of the rear lenses.
Since yours date from May 2016, I'm guessing you'd have to use a scalpel (or Dremel) to cut a hole in the back of the lenses to be able to remove the old LED board. Alternatively, delicately inserting a scalpel between the clear housing and the main body may pry the clear part free.
Later units are a simple swap over as they are unsealed.
mark10337
Switzerland
#203 Re: Series 2 aesthetics
Post by mark10337 » Mon Apr 08, 2019 1:11 pm
Are the LEDs "E" marked, like bulbs have to be? I have had a ticking off from the authorities for the reversing lights on the MOT test :sad:
-Mark
MarekH
#204 Re: Series 2 aesthetics
Post by MarekH » Tue Apr 09, 2019 10:33 am
The MGB square lights used by Jaguar will have had markings on them. The clear inserts that make a standard s2 or s3 rear light into a "Lotus" light never had any markings on them. All I have done is change the festoon bulb for a brighter array of LEDs, neither of which ever had markings.
The markings on the s2 or s3 main orange/red rear housings are exactly as before.
Jeff Cecil
#205 Re: Series 2 aesthetics
Post by Jeff Cecil » Mon Jun 17, 2019 2:22 am
#206 Re: Series 2 aesthetics
Post by Gfhug » Mon Jun 17, 2019 7:13 am
Jeff, those lights look interesting, tell us more, please
#207 Re: Series 2 aesthetics
Post by mgcjag » Mon Jun 17, 2019 7:37 am
MGB rears.....Steve
Jeff Cecil
#208 Re: Series 2 aesthetics
Post by Jeff Cecil » Mon Jun 17, 2019 11:04 am
Tbob
#209 Re: Series 2 aesthetics
Post by Tbob » Mon Jun 17, 2019 12:13 pm
Here's a couple of pics of Marek's LED reverse lights in action. White for reverse, red for brakes. Very cool!
Bob t
LHD '69 OTS. (Former) basket case
#210 Re: Series 2 aesthetics
Post by Gfhug » Mon Jun 17, 2019 12:47 pm
Jeff Cecil wrote: ↑
(please note proper spellin')
:bigrin:
Jeff Cecil
#211 Re: Series 2 aesthetics
Post by Jeff Cecil » Wed Jun 26, 2019 10:32 pm
Jeff Cecil
#212 Re: Series 2 aesthetics
Post by Jeff Cecil » Thu Jul 18, 2019 12:45 am
#213 Re: Series 2 aesthetics
Post by mgcjag » Thu Jul 18, 2019 7:43 am
Ok.....dont like the colour of the rear numberplate....dosnt really go with the paintwork.....and dosnt look straight
#214 Re: Series 2 aesthetics
Post by chrisfell » Thu Jul 18, 2019 7:57 am
And the sky is way too blue, it needs clouds.
Jeff Cecil
#215 Re: Series 2 aesthetics
Post by Jeff Cecil » Thu Jul 18, 2019 3:24 pm
Jeff Cecil
#216 Re: Series 2 aesthetics
Post by Jeff Cecil » Fri Jul 19, 2019 1:23 pm
johnetype
#217 Re: Series 2 aesthetics
Post by johnetype » Sat Jul 20, 2019 9:16 pm
If you're looking for comments on atheistics, it's got to be about the super wide Series 2 rubber bumper to body seal. Far from worrying if the number plate is straight, change that rubber strip for the Series 1 narrow one today. :bigrin:
1969 Series 2 FHC
FHCINSC
#218 Re: Series 2 aesthetics
Post by FHCINSC » Sun Jul 21, 2019 4:03 am
Hi Jeff. Trying to get in touch with you..I’m in SC. Could you email me.
Enoreeriver at gmail. Thanks! Anthony
Jeff Cecil
#219 Re: Series 2 aesthetics
Post by Jeff Cecil » Mon Jul 22, 2019 1:33 pm
Zei220
#220 Re: Series 2 aesthetics
Post by Zei220 » Tue Jul 23, 2019 12:54 pm
Jeff Cecil wrote: ↑
deja vu :yeahthat:
Jeff, do you have the information on how you did that, please?
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
