Reaction Valve
#1 Reaction Valve
Forgive me for being Dumb but will the brakes need bleeding after fitting a new Reaction Valve.Thanks Gary.
Brake fluid is cheap and bleeding is easy. Fluid should be changed every two years anyway. I use a Mity-vac which helps enormously when single handed.
The Reaction Valve is part of the vacuum circuit not the hydraulic circuit so no bleeding should be required.
'71 S3 2+2
'71 S3 2+2
