IRS Access Panel Gasket
Philk
#1 IRS Access Panel Gasket
Post by Philk » Mon Aug 26, 2019 3:47 pm
Hi - does anyone know if anyone makes/stocks the rubber/foam gasket that sits under the rear IRS Access Panel? I'm having difficulty tracking one down. Many thanks!
1964 S1 3.8 OTS
cactusman
#2 Re: IRS Access Panel Gasket
Post by cactusman » Mon Aug 26, 2019 6:21 pm
I'll get shot for saying but I used a length of self adhesive foam that is used for glazing in aluminium greenhouses. It's blsck, self adhesive backed, about a centimeter wide and 2 or 3 mm deep. Can't recall where I bought it from but a roll was a few quid! :bigrin:
Philk
#3 Re: IRS Access Panel Gasket
Post by Philk » Mon Aug 26, 2019 10:55 pm
This is the gasket that was on the car originally - ideally, would be good to replace like for like.
1964 S1 3.8 OTS
#4 Re: IRS Access Panel Gasket
Post by abowie » Mon Aug 26, 2019 11:40 pm
I just use generic 1/8" foam rubber sheet from the local rubber shop. You can't see it at all.
Philk
#5 Re: IRS Access Panel Gasket
Post by Philk » Tue Aug 27, 2019 9:57 am
abowie wrote: ↑
Many thanks...… That's what I shall do. I did speak to one of the main suppliers this morning and they do not stock these (nor cannot recall ever doing so).
1964 S1 3.8 OTS
