So sad, FIRE
ralphr1780
Topic author - Posts: 1103
dal2.0litrefrogeye
#2 Re: So sad, FIRE
Not good to see at all , but why was the bonnet not popped and extinguished at source, think it's worth us taking a look on you tube at how to tackle car fires quickly and at source tutorial
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
#3 Re: So sad, FIRE
Would you really want to get up close..lean over the bonnet to unclip it then lift it up....you could get a big rush of flame straight at you......its only a car...personaly i would let it go.....fire is s dangerous thing if you get up close....if there is s bit of smoke then maybee....but once you see flames beware
dal2.0litrefrogeye
#4 Re: So sad, FIRE
Yes I would be unclipping bonnet centre release , then cautiously lifting from the lower wing
Moeregaard
#5 Re: So sad, FIRE
That bonnet latch probably got very warm very quickly. Hopefully, they were able to save the car. This just illustrates the necessity of keeping all fuel-system components in top-notch condition. If the car has been sitting a long time, plan on a carb rebuild at the very least.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
#6 Re: So sad, FIRE
There are countless requests for help on forums for V12 E Type that have come out of storage and developed a fuel leak at the base of the stromberg. Generally its the o ring that has dried out and hardened. The carbs sit directly above the exhaust manifold shields.
If starting for the first time after a layup period, have someone switch on the ignition whilst you check each carb in turn, it will be very apparent if they are leaking as it’s under about 3lbs psi of pressure.
#7 Re: So sad, FIRE
Irrespective of people's views on opening the bonnet, I think it is good advice to learn HOW to use a fire extinguisher effectively. It may be that only one is available so you need to make the best use of it. It is no good wafting powder or CO 2 all over the flames from a distance, this will merely suppress the flames, only for the fire to gain strength again. You need to get right to the base of the fire to extinguish it.
Hopefully you will never need an extinguisher but there's no harm in having a look at a tutorial online.
dal2.0litrefrogeye
#8 Re: So sad, FIRE
So on the back of wether or not to open latch on bonnet , just had an Idea, I'm going to cable tie to the fire extinguisher s in my cars a pair of fire retardant gloves
#9 Re: So sad, FIRE
Hi Darren....there you go....at least it got you thinking a but of safety first
Monkeyfinger
#10 Re: So sad, FIRE
Seems appropriate to ask for people's advice/recommendation for extinguisher type and size. I will certainly be carrying one when my car returns from its part restoration. Fully agree that tackling a fire needs careful consideration, but I certainly want to know that I have the best option with me in the car.
#11 Re: So sad, FIRE
Hi Richard...As far as im aware your only real option is Dry powder Extinguishers. ....Foam are not for use where you have live electrics and CO2 are not for use outdoors as the gas will blow and dispurse in the air....Steve
Edit...If in the Garage then CO2 is an option....And note Julians comments below re foam
#12 Re: So sad, FIRE
Halon is the very best but now banned by the EU except in aerospace and in the US along with other countries.
budmarston@aol.com
#13 Re: So sad, FIRE
Hello,
While at a Jaguar concours show several years ago, a newly arrived car began smoking from underneath the hood. (The car was a vintage Cadillac belonging to a sponsor of the show.)
- The car smoked for 5 minutes while the owner looked for an extinguisher.
- Immediately on raising the hood, a major fire started with flames a foot high. The fire was extinguished within minutes but not without major damage to the engine bay.
Recommendation:
- Be prepared for a major fire as soon as the hood of a smoking engine bay is raised.
- Perhaps raising the hood just a few inches before using an extinguisher might have mitigated the fire.
Recommendation:
dal2.0litrefrogeye
#14 Re: So sad, FIRE
Adding a earth isolator key / switch isn't a bad idea , many electrical fires smoke for a fair chunk of time before they actually ignite
#15 Re: So sad, FIRE
As said normal foam should not be used on household electrical fires as it will conduct and thus present a risk of electrocution if sprayed at mains wiring. Cars operate at 12 volts so I see no electrical reason not to use foam if the fire is electrical although there may be reasons not to use foam on fuel or hydraulic fluid fires. As always, prevention is better than cure so inspect wiring and fuel lines regularly and address any issues before they can become serious. Rubber hoses and seals perish! Incidentally e.g. Demon tweaks sell a range of fire extinguisher kits. FIA approved . They use foam. Lots of mess but presumably pretty effective.
#16 Re: So sad, FIRE
Hi Julian...yes your correct re the foam.....was a bit quick posting above..was thinking of foam not suitable for home/garage electrics.....Steve
#17 Re: So sad, FIRE
Absolutely Steve. Aqueous foam in a garage where it may come into contact with mains power is inadvisable.
#18 Re: So sad, FIRE
This is a great shame, and I think something we all think about very often. Instances of fires are on the increase no doubt in large part to the corrosive nature of Ethanol fuel on rubber fuel pipes. I have just restored a 1976 XJS with Fuel injection and 30 psi fuel pressure. I have changed all the fuel lines to pressure rated and Ethanol rated hose. However, one still needs a spark for fuel the petrol to ignite. There is a constant stream of XJS fires being reported on other threads. I was surprised to see my brand new HT leads were sparking on two plugs between the caps and the cylinder head. So my next task is to source some very high quality, not Chinese, HT lead sets. I reckon Bosch still protects its name and produces very high quality products. For my fellow V12 owners, I would be inclined to run the engine at night and observe whether there are any sparks from your leads. On the XJS, one has the added problem that there is a wiring loom for the fuel injection which tends ( like HT leads also ) to get brittle and split from the enormous heat in the valley of a V12. So I do reckon a lot of these fires are avoidable, but really you need to do the service work to keep safe. My XJ12 is next, particular after the above fire on a standard 3 psi system.
#19 Re: So sad, FIRE
I believe that the Fire Brigade advice in the UK is to try and pop the latch(es) before you jump out. That way, when they turn up with all the gear they have a better chance of opening the bonnet and getting at the seat of the fire.
1965 Series 1 4.2 FHC
Mark Gordon
#20 Re: So sad, FIRE
I was talking with a guy at a show recently who had both a Halon and a dry chemical extinguisher in his car. I asked him why he carried both and he said, "In case of fire, the Halon is for my car, the dry chemical is for yours."
