John, how easily did the impeller turn when you had the kit fully installed as you describe?
I’ve followed your instructions, as, like others found, there are no clear instructions from SNGB how to fit the items. Yet when the impeller is at the 15 thou clearance it is very stiff to turn as the seal is compressed and puts a lot of friction on the shaft.
Thinking I had fitted things badly I took it all apart, once the pressure is off the seal the impeller turns freely.
But, and it’s a big but, having taken it all apart I found the impeller had cracked with the effort of pressing it onto the shaft. Not at all impressed by this
