Gear lever gaiter
basilruler1234
Topic author - Posts: 27
#1 Gear lever gaiter
I've read as many of the threads on this as I can find but I can't seem to find the answer to this question, so hoping the forum can help. Can anyone tell me how the base of the gear lever gaiter is secured in position at its base? I've attached a photo of a demo as a picture tells a thousand words and all that, thank you.
- Attachments
- _20191209_081734.JPG (130.93 KiB) Viewed 4923 times
James Guest
Series 1 4.2 '65
Series 1 4.2 '65
#2 Re: Gear lever gaiter
Hi James..have a look at this post....3rd photo......the leather is attached to a metal retainer.....which is then held in place by small lugs undreneath....have a look at a parts catalogue...SNG for example....Steve viewtopic.php?f=5&t=5652 PS if your wanting to remove leather gaiter you need to remove center consuke and access from underneath
basilruler1234
#3 Re: Gear lever gaiter
I had seen this post but couldn't see how the metal ring was held in place. Are the lugs attached to the blister and the ring held between the blister underside and the lug then?
James Guest
Series 1 4.2 '65
Series 1 4.2 '65
#4 Re: Gear lever gaiter
Yes https://www.sngbarratt.com/uk/#!/Englis ... OX%20COVER part number 28 held in position from underneath by lugs in part 23
basilruler1234
#5 Re: Gear lever gaiter
Perfect, thanks for the info
James Guest
Series 1 4.2 '65
Series 1 4.2 '65
#6 Re: Gear lever gaiter
Have you got an S2 gearbox tunnel & gauntlet fitted to your S1 then? The S1s just have the rubber glove thingy.
Or so I understand - I'm not much of an expert on trim changes etc.
1965 Series 1 4.2 FHC
#7 Re: Gear lever gaiter
The early 4.2 cars had the rubber gaitor but that was replaced by an Ambla (faux leather) sleeve in about 1967.
