Tighten the cylinder block studs ( plain and dowel )
Mich7920
#1 Tighten the cylinder block studs ( plain and dowel )
Post by Mich7920 » Fri Jan 24, 2020 11:21 am
Hi all,
Could somebody confirm me the value ?
I found 56lb/ft into a previous message but the forumer wasn't sure.
I don't find in the service manual.
Mich
Michel
#2 Re: Tighten the cylinder block studs ( plain and dowel )
Post by mgcjag » Fri Jan 24, 2020 11:33 am
Hi Mich...service manual page B8 shows 54ftlb this was revised in a service bulletin...note engine numbers
Mich7920
#3 Re: Tighten the cylinder block studs ( plain and dowel )
Post by Mich7920 » Fri Jan 24, 2020 12:05 pm
Steve,
I know this for the nuts but I would like the torque for the studs
Mich
Michel
#4 Re: Tighten the cylinder block studs ( plain and dowel )
Post by mgcjag » Fri Jan 24, 2020 3:30 pm
Hi Mich.....as far as im aware the studs are not torqued ....they should be screwed in fully and tight to the bottom of the cleaned out threaded hole.....if there are torque figures im sure someone will let us know....Steve
Mich7920
#5 Re: Tighten the cylinder block studs ( plain and dowel )
Post by Mich7920 » Fri Jan 24, 2020 4:37 pm
Thanks Steve.
Wait and see
Michel
#6 Re: Tighten the cylinder block studs ( plain and dowel )
Post by malcolm » Fri Jan 24, 2020 5:15 pm
I was told (by someone who knows far better than I)(although that's not hard :bigrin: ) that you just tighten them by hand then pinch them up. No torque setting, don't overtighten.
#7 Re: Tighten the cylinder block studs ( plain and dowel )
Post by abowie » Fri Jan 24, 2020 10:58 pm
malcolm wrote: ↑
This is correct. We put a generous amount of stud sealant on the bottom thread and then just screw them in finger tight. Obviously they need to be fully inserted down to the block face.
If you consider that the stud pulls against the block threads and stretches as you torque the nuts up, so acting like a spring, it makes it easier to understand.
Mich7920
#8 Re: Tighten the cylinder block studs ( plain and dowel )
Post by Mich7920 » Sat Jan 25, 2020 9:01 am
Thanks Malcolm and Andrew
Michel
#9 Re: Tighten the cylinder block studs ( plain and dowel )
Post by malcolm » Sat Jan 25, 2020 10:04 am
abowie wrote: ↑
malcolm wrote: ↑
Bloody hell! I got a technical thing right! That's a first. :wow:
1954Etype
#10 Re: Tighten the cylinder block studs ( plain and dowel )
Post by 1954Etype » Sat Jan 25, 2020 1:36 pm
Don’t forget the copper washers.
Angus 67 FHC 1E33656
61 OTS 875047
#11 Re: Tighten the cylinder block studs ( plain and dowel )
Post by mgcjag » Sun Jan 26, 2020 6:51 pm
Hi Angus....what copper washers?
#12 Re: Tighten the cylinder block studs ( plain and dowel )
Post by christopher storey » Sun Jan 26, 2020 7:24 pm
:yeahthat:
1954Etype
#13 Re: Tighten the cylinder block studs ( plain and dowel )
Post by 1954Etype » Sun Jan 26, 2020 8:02 pm
The 5/16 ones that go on the studs pointing down.
61 OTS 875047
Mich7920
#14 Re: Tighten the cylinder block studs ( plain and dowel )
Post by Mich7920 » Sun Jan 26, 2020 8:04 pm
No I don't forget them.
thanks Angus :bigrin:
Michel
#15 Re: Tighten the cylinder block studs ( plain and dowel )
Post by mgcjag » Sun Jan 26, 2020 10:26 pm
Ah....ok front studs into timing cover....Steve
