Brake system-Refreshed and No pressure
#41 Re: Brake system-Refreshed and No pressure
Yes Coopercraft are larger four piston calipers which is why I was disappointed with the amount of effort needed at the pedal. With the 5/8" master cyls less effort was required. I notice no difference in the pedal travel if the brakes are bled of all air and the linkages adjusted correctly.
Derek
#42 Re: Brake system-Refreshed and No pressure
Good news. Thanks
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#43 Re: Brake system-Refreshed and No pressure
Do you know the piston size?
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#44 Re: Brake system-Refreshed and No pressure
Sorry Layne, I don't know the piston size. I believe they are the same as Ser 2 front caliper small pistons, just four of them instead of two alongside a larger one. Coopercraft don't state the size on their website but if I can verify I'll post it. The benefit to me was the increased brake pad area.
Derek
#45 Re: Brake system-Refreshed and No pressure
Thanks for the info. Yes, Coopercraft site keeps it a secret
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#46 Re: Brake system-Refreshed and No pressure
Brakes are functioning well with good balance front to rear. Broke in new pads and have tested with hard braking with positive results. Have installed original Dunlop 5/8" MCs with different stroke distances, orig front calipers to rear, and the Wilwood 4 piston (small pistons) at the front. Finally got it bled out which was more of an issue than it should have been but evidently had a stubborn pocket that we worked out.
Thanks for all the help.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
#47 Re: Brake system-Refreshed and No pressure
I have exactly the same problem, I will let you know when (if!) I find a solution.
Tried everything, every method, every suggestion, still got air in rear system. Clamping the flexi (to rear cage) gives a solid pedal so the M/C is fine.
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
66 FHC (QUAD LIGHTS)
61 flat floor DHC
61 FHC
63 FHC
#48 Re: Brake system-Refreshed and No pressure
I did get it, just drove and bled, drove and bled. Why? Don't know.
Layne
Car #876005, 62 OTS
Car #876005, 62 OTS
