When I start my 72 Series 3 2+2 from cold, I always get some light gray smoking out the tail pipe. It lasts for about 3-4 minutes, getting progressively lighter until it stops. After that, the exhaust is clean (at least to the naked eye). Other than that, the car runs well and sounds good.
In the cold weather, I also get lots of steam and moisture (see photo) that carries black residue to the ground.
I'm guessing this means that I'm burning oil somewhere but is it worth worrying about? I realize this is symptomatic of some problem, but I'm not a mechanic and before I spend a small fortune on new valve guides or piston rings, I need some sense of proportion.
Thanks in advance for your advice.
