Brake system-Refreshed and No pressure
dxke38
#41 Re: Brake system-Refreshed and No pressure
Post by dxke38 » Fri Feb 07, 2020 8:57 pm
Yes Coopercraft are larger four piston calipers which is why I was disappointed with the amount of effort needed at the pedal. With the 5/8" master cyls less effort was required. I notice no difference in the pedal travel if the brakes are bled of all air and the linkages adjusted correctly.
Derek
mtnjag
#42 Re: Brake system-Refreshed and No pressure
Post by mtnjag » Fri Feb 07, 2020 9:07 pm
Good news. Thanks
Layne
Car #876005, 62 OTS
mtnjag
#43 Re: Brake system-Refreshed and No pressure
Post by mtnjag » Fri Feb 07, 2020 9:08 pm
Do you know the piston size?
Layne
Car #876005, 62 OTS
dxke38
#44 Re: Brake system-Refreshed and No pressure
Post by dxke38 » Fri Feb 07, 2020 9:30 pm
Sorry Layne, I don't know the piston size. I believe they are the same as Ser 2 front caliper small pistons, just four of them instead of two alongside a larger one. Coopercraft don't state the size on their website but if I can verify I'll post it. The benefit to me was the increased brake pad area.
Derek
mtnjag
#45 Re: Brake system-Refreshed and No pressure
Post by mtnjag » Sat Feb 08, 2020 1:54 pm
Thanks for the info. Yes, Coopercraft site keeps it a secret
Layne
Car #876005, 62 OTS
mtnjag
#46 Re: Brake system-Refreshed and No pressure
Post by mtnjag » Sat Mar 28, 2020 7:16 pm
Brakes are functioning well with good balance front to rear. Broke in new pads and have tested with hard braking with positive results. Have installed original Dunlop 5/8" MCs with different stroke distances, orig front calipers to rear, and the Wilwood 4 piston (small pistons) at the front. Finally got it bled out which was more of an issue than it should have been but evidently had a stubborn pocket that we worked out.
Thanks for all the help.
Layne
Car #876005, 62 OTS
poofacio
#47 Re: Brake system-Refreshed and No pressure
Post by poofacio » Fri Nov 06, 2020 12:50 am
I have exactly the same problem, I will let you know when (if!) I find a solution.
Tried everything, every method, every suggestion, still got air in rear system. Clamping the flexi (to rear cage) gives a solid pedal so the M/C is fine.
61 RHD OBL DHC
61 flat floor DHC
61 FHC
63 FHC
66 FHC (QUAD LIGHTS)
mtnjag
#48 Re: Brake system-Refreshed and No pressure
Post by mtnjag » Fri Nov 06, 2020 1:40 am
I did get it, just drove and bled, drove and bled. Why? Don't know.
Layne
Car #876005, 62 OTS
