Has anybody ever managed to repair this area?
I also have a similar problem with the ones in the roof and one of them has a plastic rawl plug stuck in the hole. So I have to do something with this too.
It's not clear but I should have said the body is in primer and hasn't been painted yet.abowie wrote: ↑Sun May 03, 2020 11:23 pmDoes the chrome support for the rear window locate properly in one of those holes?
If it does you could leave the mess for posterity.
Otherwise I'd be trying to cut off the threaded plate and making one that fits, then gluing it back in place, which should save your paint.
Then now's the time to go in from the top and fix it properly. Open the panel up, replace the plate with a new one and then weld the panel back and repair. This is probably the ideal solution as that plate is supposed to slide to make adjustment possible.PaulColeman wrote: ↑Mon May 04, 2020 12:00 pm
It looks like quite a tricky panel to cut out. I've got a 4" angle grinder but I'm going to need something a little more delicate than that. Has anybody got any good ideas? Drilling a series of holes would be a bit messy...
