Brake issue after rebuild
Kingkitesurf
Netherlands
#1 Brake issue after rebuild
Post by Kingkitesurf » Wed May 13, 2020 9:16 pm
A very strange thing occurs with my completely rebuild brakes. Everything is new. New master, new booster, new lines, new pistons, new 4 pot front upgrade, new bottles, new fluid. After bleeding the lines with a pressure bottle system (1.2 Bar) and parallel using a vacuum suction system on the bleeder end there still seems air in the system. First press is deeper then the second one. After the second push I am trying to hold pressure and it very very slowly keeps dropping. I did not start the car (so maybe no vacuum activation yet)…
Checked all connections and lines but no leaking.
As there was almost 1 liter of brake fluid in the vacuum canister before rebuild I suspect the valve on the vacuum canister could be faulty?
What else can this be? Faulty new part like master cylinder?
Job
1968 E-type 4.2 S1.5 FHC
Tom W
#2 Re: Brake issue after rebuild
Post by Tom W » Wed May 13, 2020 9:27 pm
Are you sure there’s no air in the system? What fluid are you using?
Tom
1970 S2 FHC
dal2.0litrefrogeye
#3 Re: Brake issue after rebuild
Post by dal2.0litrefrogeye » Thu May 14, 2020 9:26 pm
Hi so if I'm reading this right with your foot on the pedal pushing down , it will slowly sink to the floor ? ......... sounds like your new master cylinder is letting by ,
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
