The Sticky Out Indicator Pod
sideways60
Topic author - Posts: 50
#1 The Sticky Out Indicator Pod
Can the Pod's be Purchased ? , my S3 NSF is not Right TIA . Russ
#2 Re: The Sticky Out Indicator Pod
If your searching for a "Sticky out thing" you will have trouble finding the correct part.......Do you mean the front side indicator lamp?...if so yes available...just google....Steve
#3 Re: The Sticky Out Indicator Pod
I have a hunch Russ might be after the sheet metalwork insert into the bellypan, not the actual chromed (pot metal) indicator housing. I have a few in the loft somewhere.
sideways60
#4 Re: The Sticky Out Indicator Pod
Yes Merek , Not the Light Unit , The Pod Itself { Howsing } , if you Could Pls Merek Thanks Russ .
