Post
by Drive35 » Fri Jul 10, 2020 9:29 pm
Great information on here, thanks.
I've just replaced my LH door hinge with a used item that has the screw-in light switch. My old one had the plate-mounted type and 2 extra wires, which I hadn't realised was for a buzzer, however can't get any noise, when the key is in the ignition & switch in any position.
Anyone know what the buzzer looks like, or where it is?? The wiring around the ignition switch has had mods in the past, so don't know if the buzzer is actually there or still connected.
Chris - did you manage to get a switch? I won't need my old one if that's any use to you, although not actually sure it works yet!
1970 S2 2+2
